fx1 , reed removal.
Hey guys , I need to remove the reeds from my 95 fx1 , apart from a protec exhaust the engine is stock. Can this be done with the engine still in the ski , or is it an engine out job... ? Any advice would be great....
Quinc
Buy a Superjet
California
You just take off the intake manifold. Do a search and download the Superjet Manual pdf, It is also covers the Fx1.
  • Like
Reactions: mk1
Quinc
Buy a Superjet
California
That's it, you just need to pull them from there. The gasket is causing it to stick. If it is really stuck you can very carefully go along the edge with a razer blade. There may even be a small indent on each side so you can use a screw driver to help pop them out. Just be careful and work then out slowly.
  • Like
Reactions: mk1
I got the top off the inlet manifold , but the reeds seem to be inside the lower section of the manifold. Looks like I need to remove this too , but can`t locate bolts... (Engine is still in ski).
What reeds are you gonna run I just put some boyseen power reeds in mine gonna run it this weekend see how it does.
