Here are a few things I'd like to sell so I can cleanup the garage. They've just been sitting on the shelf. I'm guessing on some of the prices just to get a number on it per site rules. If something is outrageously priced, let's talk about it. I want to sell this stuff. Pics available on request. Prices do not include shipping since many of these are small items.
Flywheel, stator, cover, bendix, starter
OEM 62T flywheel (excellent) painted grey $100.00
OEM 62t flywheel (excellent) $100.00
OEM flywheel bolt & OEM woodruff key $30.00
OEM flywheel cover $15.00
OEM flywheel cover w/oil injection plug (includes hardware) $20.00
OEM Blaster stator (excellent) (61x?) $140.00
OEM Mitsuba starter (great shape) $180.00
Starter (spins smooth) $120.00
Electrical, wiring, S/S, ebox, CDI
OEM Blaster ebox (absolutely mint condition & includes stator) $500.00
OEM ebox shell (salty and includes S/S harness & voltage regulator) $40.00
OEM ebox to S/S switch harness (brand new) $40.00
OEM ground cable $20.00
OEM S/S internals (brand new) $80.00
OEM Blaster S/S switch $80.00
OEM SJ S/S switch (missing red button but still works fine) $80.00
OEM SJ ebox mounts w/hardware $25.00
OEM ebox mounts (no hardware) $20.00
Carbs, intake, cylinder, pistons, cyl head, airboxes
46mm single Mikuni race carb $200.00
61x OEM intake mani w/ OEM reeds & throttle plate $70.00
OEM 61x cylinder (excellent) includes original pistons, rings, wrist pins & bearings) $500.00
OEM cast pistons from 701 (decent condition, includes rings) $30.00
MRD two-piece cylinder head (good shape) w/girdle kit $140.00
OEM cylinder head (excellent) $40.00
OEM RN airbox with all mounting hardware & screens (excellent) $70.00
OEM airbox w/screens (no screws to mount plate to carbs) $65.00
Motor mounts, bedplates
OEM motor mount hardware kit & OEM motor shims $40.00
OEM Blaster motor mounts (excellent) $60.00
OEM bedplates w/hardware (great shape) $40.00
OEM bedplates no hardware $20.00
OEM bedplates w/hardware (excellent condition) $45.00
Hood
OEM SJ hood prongs w/hardware (fits on hood) $20.00
OEM hood latch complete (including hardware & catch) $60.00
OEM hood latch w/hardware (no catch) $35.00
OEM SJ hood breather hoses (hose clamps can be included) $15.00
Fuel, throttle
OEM rubber tank bumper $8.00
OEM SJ fuel tank hose (hose clamps can be included) $40.00
OEM fuel tank straps
OEM fuel filter mount $8.00
OEM fuel fill cap & mount (white) $15.00
OEM RN throttle cable (small rub spot) $25.00
OEM RN throttle cable (big rub spot) $10.00
OEM RN throttle cable (some rub spots) $20.00
OEM throttle $10.00
Exhaust, cases, crankshaft, waterbox
OEM 701 crank (excellent, all bearings are smooth) $200.00
Hotrods 701 crank (seems good, don't know its story) $100.00
OEM waterbox straps $20.00
OEM SJ waterbox rubber mat $10.00
OEM RN waterbox mounts $10.00
Pump, prop, driveshaft, midshaft
61X OEM reduction nozzle & turn nozzle (excellent condition) $100.00
OEM pump bolts w/pump shims $40.00
Skat Trak 13-17 prop (1 dent as shown) $100.00
OEM coupler dampener (excellent) $15.00
OEM Blaster driveshaft w/bearings (Excellent condition, excellent splines, literally looks new) $240.00
OEM Blaster pump/prop w/hardware (damage on stator veins) $50.00
OEM SJ (pre-08) driveshaft BENT (splines are excellent) $40.00
OEM RN coupler with dampener (excellent & complete) $60.00
Hull, handling, flotation
New Blowsion Destroyer II tubbies $350
OEM RN handlepole bracket w/hardware (excellent condition) $50.00
UMI Blaster handlebars with throttle & grips (great shape) $80.00
OEM Blaster handlebars w/OEM throttle & grips $40.00
Unknown Blaster handlebars $30.00
OEM SJ steering stop (complete) $8.00
Handlepole spring $50.00
OEM siphon w/hose $10.00
OEM siphon mount $10.00
OEM RN nose foam $15.00
OEM couch mounts
Good condition, no cracks or problems. Some of the holes have been enlarged a bit for alignment.
$60 shipped CONUS
OEM intake manifold
Perfect condition, appears to be new. Includes one new gasket.
$70 shipped CONUS
Hood
Fuel, throttle
OEM throttle $10.00
OEM couch mounts
$60 shipped CONUS
OEM intake manifold
$70 shipped CONUS
