- Harveys Lake PA
I guess I'll be the first to post in here. There are so many mixed reviews on gelcoat and an epoxy layup. We have been searching and have only found one company, Scott Bader inc. that makes a polyester gelcoat specifically designed to bond with epoxy. Link to product here:
http://www.contender.it/joomla/images/documenti/2011/Epoxy/Scott_Bader_Polyester_epoxy_gelcoat.pdf
It's roughly $5.50 per lb and that's close to 260.00 for their minimum quantity of 5 gallons. The only issue is they do not stock the product in the USA. Lead times will be a pain. I'm curious to see what the rest of you are doing?
The other thought was pigmented epoxy brushed into the mold to give a starting surface. However there is no uv protection and it will still need to be painted.
