Gen 1 BOB 838 Dasa PV **SOLD **
Gen 1 BOB #22 if I'm not mistaken. Great running real bad ass ski. Tim Judge built 7 port cast Dasa PV cylinder 85.5mm bore. ADA girdled head w/ 2 sets of custom domes ( pump gas & race gas). Ported and epoxied cases w/5 mm stroker. Engine has 2.5 gallons of fuel run through it in the water tank being tuned @marine power sports in Glen Burnie, Md. and only 7.5 gallons ran through it in the water. Ski has 12 vein 144 mag pump w/9-15 impeller, bored reduction nozzle (85mm), extended Pro-Tec nozzle and thrust innovations trim kit. Msd analog TL ignition (and a spare msd analog tl setup), 48mm blackjack carbs and v force 2 reed setup. This BOB has a custom pancake pete foothold in the frt of the tray and widened side rails on the hull. Handlepole is a full carbon XFT unit witn a cold fusion quick steer setup. I have too many skis and not enough time to ride. Looking for 7700 dollars for this unit w/ clean and clear Md. Title. Any questions call Vince at 240 417 3867 or send message. Thanks for the interest. In sure I'm forgetting a detail or two
