Glue cutting experience on sxr
Hello all!
like to take al te glue out of my sxr hull there's to much looks ugly! Anyone have the gold tip...i have used a smal grinding weel lots of dust not fast enough and a powerd cuttingtool same!
How did you do it ?
Greets
PNW
60 grit wheel sander worked good with a die grinder. Have a buddy holding the shop vac right on the grinding and make sure to wear masks. It's messy
What powered cutting tool did you use?
I used an oscillating multifunction tool. It cut really fast through it with the right toothed blade. You just need to watch out that you are not cutting the hull. You end up cutting off strips of the glue instead of grinding it all away. Still made dust, but a whole lot quicker and less dust than grinding/sanding.
http://www.harborfreight.com/variable-speed-multifunction-power-tool-67537.html
