Super Jet glueing scupper to flex pvc
whats the best stuff to use to glue scupper to flex pvc, thickened epoxy, 3m 5200, etc, i tried useing pc-11 marine epoxy, dont know if i got in to big of a hurry and didnt prep flex pipe good enough, grabbed the flex pipe, and scupper and twisted and broke it lose.
Send a pm to Papp on here. He will make you a full carbon Papp plug. Same idea as a Versa plug but 3x the size hole and completely outta carbon . No more PVC not bonding :):):):)
yeah freestyle, i ended up useing epoxy resin thickened with cabasol, Its worked good so far, if i cant grab the pipe and scupper and twist it loose i dont c it going anywhere once i install, sxr07 a carbon tube would b sweet, ill keep him in mind. cant wait any longer on getting stuff. gotta get this build done, need to install scupper tube, and start putting foam in tray so i can get her done,
