I was looking at some others vids and their shots seem alot wider than mine, now granted they might not be using a GO Pro. I have mine on setting 5 which is1080 i think, what do others use and what do you use to edit?
Can't remember what setting I use, but it's the least wide angle possible. But I mainly use it on my helmet. If the cam is on the nose area looking back at you, the wider angle may work better for you.
I've been using r5 because it's not as wide as the others which I think helps with the fish eye effect. Haven't really played with the other settings though. For editing I use Sony Vegas Movie Studio, but it wont work with .mp4 files so I have to convert it. I saw GoPro suggested Pinnacle Studio HD for editing with a pc so I'll probably give it a try.
r1 Wide Angle Standard Def 16:9 WVGA(848x480) 60fps
r2 Widest HD Video 16:9 720p(1280x720) 30fps
r3 Widest HD Video 16:9 720p(1280x720) 60fps (same as r2, but with ultra slow playback)
r4(default) Tallest HD Video Max Overall View 4:3 960p(1280x960) 30fps
r5 Full HD Highest Resolution 16:9 1080p(1920x1080) 30fps Has 25% narrower field of view(127) where the other resolution have 170
