- Cherry Valley, CA
okay i have a 650sx and i pulled teh motor because the mounts are wasted and i was gunna clean some of the crap on the bottom of it and put some appliance epoxy inside the hull. the only problem is that like on each motor mount a bolt broke inside the hull that holds the mount to the actual hull. i drilled the bolts and tried using an easy out but that thing broke in the hole i made. i even applied some heat on there too. so i was thinking maybe i can epoxy some studs in there instead of using bolts to hold the motor down. waht would i be risking running only 1 bolt on each motor mount?? also do you guys know where i could get the weather pack plugs??? im going to have hookups for all the wiring so i can make easy engine removal. thanks for any help!!
:djsmilie:
:djsmilie:
