Gp 800 / 927 junk
DylanS
Gorilla Smasher
Lebanon Pa
Cleaning the shop out of all the odds and ends
- Set of clean matching numbers gp800 engine cases that have been machined to accept the adapter plates to run in a stand up, comes with half studs
Asking 200 plus the ride.
- two sleeved cyls at 87 bore, nothing that catches nail but not pretty. Not sure the back story on these, when I received them they came with a 5mm stroker crank I’m assuming someone was trying to play with the port timing.
The head bolts were all over sized with helicoils. Comes with two riva heads that were cut to clear the pistons with the stroker crank. Have run them before with no issues.
Asking 400 for the set w heads.
-two 87 bore nikasilled cylinders, no nail catchers, someone molested the exhaust ports at some point. I never ran them I didn’t trust how far the ring could poke as is but you do you. The top exhaust port work is sloppy and uneven if it’s not clear in the images. Asking 300 for the set.
Everything is obo. Will let it all go as a package for cheaper. Thanks for grazing your eyes.
DylanS
Gorilla Smasher
Lebanon Pa
More pics available upon request
WFO Speedracer
Alabama
For sure either a sleeved cylinder or a pair of stock Nikasil cylinders , I haven't pulled the bottom end to see if the cases are still good and I know for sure the crank is toasted..
Pretty sure the”WaterDouche” himself did the porting on the 2nd set. I’ve seen his “style” on another motor he ripped someone off on. This particular motor had a bent rod eBay crank as well. But hey….”he sold cheap hulls”. GLWS
DylanS
Gorilla Smasher
Lebanon Pa
Yeah it’s funny when I text him and asked if he did it he responded with “who told you that” and never again. How did you know that wtf lol I had this sitting in my shop for years
