- Central Ny
Wanted to get into stand-up jet ski's. Decided to try the jump in head first approach. Researched as best I could and then bought a ski off craigslist. Figure not worth the stress of trying to find the perfect ski, just start with whatever I find and learn from there. This is what it looked like when I first got it... Noticed the 2 cooling lines coming off the head...
Here's my problem... I had to ditch that engine. It had no compression on one cylinder and I couldn't get the head off due to corrosion (lesson learned. Never buying another engine again without checking compression). Brought to a kawasaki mechanic he couldnt get the thing apart either... (btw if anyones interested in a ocean pro head - corrosion welded to free spinning engine with low compression in one cylinder )
So I found a very very beat up X2 with a good engine and got that in(I know people are probably wondering why I didnt try to save the X2 instead, but it was a basket case. Electrical was fried, severe hull damage). But it's the stock engine with a single cooling line coming off the head. So now I have 2 lines coming off the impeller, 1 line in at the manifold, 1 line off at the head, and 2 pissers?
set up is currently like this (edit: Crap I labeled both lines, "line 2" those are each separate lines coming from the impeller)...
and I'm thinking I'll hook it up like this...
Is there a better way to organize it and utilize the second cooling line?
Thanks!
p.s. Do you need a fuel pump with the 38mm Keihen carb? The carb only has an in and out, no pulse line. Pulse line was blocked off when I got the ski, no fuel pump to be found. I've never run the engine long enough to test how it sucks up fuel X_X
Thanks!
