I was looking to swap out my stock pole to the thrust innovations handlepole I have. This is going on a 2003 RN SJ. It looks like I can use the factory bracket without any major issue. It does not look like I can use the pole spring, however. Do any of you run a thrust innovations pole with a pole spring? If so, do I need to change the pole bracket to make it work or buy a different spring? Currently, I'm running a WDK lowered pole bracket and Wamiltons lowered hood kit. Thanks for the input.
