Hangover+wrench=empty wallet.
yamanube
This Is The Way
Staff member
Mandalor
Just made the dumbest mistake I have made to date working on my ski today. Forgot to put the tapered end on my flywheel puller and pushed about 3/8" of threads out of the nose of my crank. I feel like a complete idiot and may have ruined a perfectly good crank...just wanted to share it with somebody.
yamanube
This Is The Way
Staff member
Mandalor
Does anybody know if the threads on the crank go all the way to the end or is there a section that is unthreaded?
Threads
The threads are plenty deep(if you have an OEM crank). I have seen this before. Just chase the threads, clean the threads and bolt with Acetone. Use red loc-tite and torque to the correct specs. I personally torque to 75 foot lbs.
Good luck,
Randy
felix5oh
Carajo,gringos apestosos
Miami,FL
helicoil is a dumb idea.
Just try to tap it put it together. If it fails ,you can most certainly go up one size with a new bolt. Much cheeper than a new crank.
yamanube
This Is The Way
Staff member
Mandalor
Just looked in the end and the threads start pretty deep in there (looked like deaper than how far I think it went in). Pulled one of my core cranks out of the bin and looked at that and sure enough the threads start about 1/2" in. Looks like my brain started working just in time and I stopped about 1/8" before I hit the threads...the crank is good. Huge relief!
