- lake orion MI
Just a prototype of our dual hauler ... can ONLY be used with a class 5 hitch receiver which comes on 2016 and newer HD trucks ( i believe) . This is a 2 piece design so that it will break down into two separate carries if needed. Before you say its too much weight ect .. its been tested in the field for a lengthy amount of time and the only revision we have made so far is to move the rear ski about 6" closer to the front ski ( less worry )
yeah I looked into local laws and there are many ATV carriers out there that do pretty much the same thing that we're doing here as far as length and all that would be required as a red flag on the end of the farthest point of whatever you're carrying. again this was just one state patrol officer I spoke withI would give the disclaimer to check local laws since most states limit how far your load can extend from the vehicle.
What is the tongue weight conversion with the length and weight of the 2 skis currently on it?View attachment 369519
<900lbs .. receiver on truck rated at 1450lbs.What is the tongue weight conversion with the length and weight of the 2 skis currently on it?
Saw your rig in Tona. Looked good.
