Dont know if its bad but going to diss conect it what do ya do with the wires let them be in the ebox ..tape or conect together ..what have u guys done
You will need to isolate the pink and black wires within the e-box. Just tape them up good (separately). If you connect them together it will simulate over-temp and knock your rpms to minimum. Don't forget to silicone the hole in the D-shaped grommet.
Not to take away from OCD, cause he makes some damn fine products....
But I used that hole to run a auxillary ground wire (6 or 8 guage) from the battery to the e-box ground. Just an idea. As always, make sure you seal it with something awesome.
