SXR Help ID these pistons.
Mike W
Infidel
North Florida
Tore down my SXR 800 motor but need help to ID these pistons. They have an “A” stamped on the top and “ART” molded in the casting inside the skirt. They measure 81.5mm so I’m sure they’re not stock.10E91A60-3AF6-4146-9623-FB0B5754A5B5.jpegD1834FDA-D68F-4237-BADA-B6F50CA83386.jpegDC00F863-5F1E-4A3B-A3FE-54A63576FD1C.jpeg
Mike W
Infidel
North Florida
Did you measure from the bottom of the skirt? If they really measure 81.5mm, they are not Sxr pistons because Sxr cylinder bore begins at at 82mm and can be bored to 85mm typically. What cylinder did these come out of?
Stock 800 cylinders. I measured the top of the piston. Just measured the bottom of the skirts and they are 81.80mm. F8115723-7E06-4D0C-BC58-8638E53E0BEA.jpeg
Stockton
81.80, may be 82 or so collapsed. Try remeasuring the cylinder bore at the bottom of the sleeve, with just the tips of calipers and see what you get..
WFO Speedracer
Alabama
ART is who makes the OEM pistons for Kawasaki, they are a Japanese manufacturer, also pistons are not going to measure the same as the bore size, they will always be smaller, the difference between the bore size and what the pistons measure at is your cylinder to wall clearance, in this case .20mm or .004 in, nothing is collapsel nothing is wrong there unless the taper or out of round is out of spec.
Stockton
I did not feel comfortable the measurements since the piston was measured at the top first, so I directed him to measure the cylinder in the least
worn area and he was able to answer his own question.
WFO Speedracer
Alabama
The reply was more for the rest of the guys here but yes you were correct it has to be measured at the bottom of the skirt as pistons are tapered.
Mike W
Infidel
North Florida
I always left my engine building to the experts so I never dealt with this kind of thing. Being that I’m retired I better start doing the repairs myself so I appreciate the good info.
WFO Speedracer
Alabama
Also the only way to truly know the condition of that cylinder is by using a bore gauge, A caliper will only measure the bore at one spot, it has to be measured in many spots on both the X and Y axis to determine taper and out of round
