Blaster Help Identifying this pump
Guam
Hey peeps,
I pulled the pump off my Mod Hull after wrestling with the wall anchors they used to secure it, and noticed it has a stainless stator section. The wear ring is also stainless and is really thick maybe over 4mm. The bore measures 140mm, and the prop looks to be a custom pitch 13/18 from Skat. Anyone have any info on this thing, how it runs, and if I should go through the trouble of repairing it? It looks pretty beat up on the housings, but okay in the stator/ring.
My engine setup for now is a 62Tcase, DBP ported cylinders bored to 753/ stock intake mani, DBP Taper Bored 38mm carbs, Custom Girdled Head, FBP Mod Chamber, Triton Water Box, Protec grate, Protec plate, Aluminum Pump Shoe. Is this enough juice to run this kind of pump?
Thanks
227
Its all about the surf!
Oceanside, CA
Do you guys think its worth trying to repair..........
That thing looks in pretty bad shape. The SS insert pressed into a OEM housing is a very obsolete design. The last time I sent my Skat Mag in for repairs (It was in better condition than yours) the bill came out to $700! You can buy a brand new all Stainless mag pump from Solas now for around $500.
Guam
Okay, now that's the answer I was looking for. Thanks for the info now I can move forward. By the way where can you find a $500 Solas Mag pump?
Carlo
in reality, you could probably just bead or sand blast that thing, hit it with a rattle can and run it. sure its corroded but it looks like it is mechanically sound. if it was in my hands and i determined it to be useable, i'd use it. for a mag pump, its nothing special and it wont do anything extra for you, but it may beat spending money on something else that wont give you anything extra.
