- Ocala, FL
Leaving for the lake soon and just realized i dont know what ratio to mix my fx1 to. Its all stock. Im sure its the same as SJs but yahoo search failed me there too...
Go a little rich until you get a "for sure" answer. Better to foul plugs than the alternative!Leaving for the lake soon and just realized i dont know what ratio to mix my fx1 to. Its all stock. Im sure its the same as SJs but yahoo search failed me there too...
You should run the same oil for the engines whole life. If you change make sure the tank is fully empty and you arent mixing oils
