kkwedell
x-h20.com
- Walnut Creek
So I have been chasing this problem all summer. It started when I hydro locked my ski (time for a rebuild anyway). I bought new: prox pistons, had it bored over 83mm, ATP water box, new stator, and i had my flywheel lightened by #zero. I put it all together and went to start it. It just cranked and cranked without starting. I checked the spark and it is good and strong. Then I checked fuel. It was pumping fuel well. So then I checked compression. 210 both cylinders. I have an ada head, but Im not sure what domes. So fuel-compression-spark=start. So I cranked it over again..... BAM...... biggest backfire I have ever heard. So I looked at the carbs to make sure I did by mess them up. They were al good as was the exhaust. I checked the timing and it is 1 deg advance. The key was also good for the flywheel. So I looked around and that was one of the symptoms of a bad msd enhancer. So I went ahead and bought a new one. Put it all together and same thing. Only thing I can think of is a bad stator or that the crank was put together wrong by SBT. It seemed exactly like my old one. Im at a loss and am seriously just at the point where I am going to walk away.
Sent from my SCH-I535 using Tapatalk
