112motorsports
CLETUS
My ski is still pumping way too much fuel and I can't seem to figure it out. When it is barely running the PTO carb is just dumping fuel in like a garden hose. I have checked the needle and seats, the pop off over and over agina and it is still doing this. I have a remote pump feeding these carbs so there is one line from the tank to the pump, then two out of the pump to each carb and the pulse line. Then the returns are T together and feed back to the tank. I have a one way vale venting to the ATMOSPHERE. I keep getting several differant opinons on which way this should be venting. IN to the tank or OUT the the atmosphere. If anyone has any ideas and or experienced this in the past PLEASE HELP. I am at a dead end with this thing. Thank you for all of your help.
I am running 100 mains, 115 pilots, 2.5 needle and seat with a 115lb spring.
This is a standard 701 ported mod pipe ADA head dual 44.
Cheers,
Cheers,
