- Cape Canaveral, Fl
I took my pump off and all the female threads were corroded (no loctite or silicone from previous owner, 96 RN). The rear two bolt holes are fine but the front two are in bad shape. One of them is stripped 3/4 of the way (bolt stays in but does not provide any holding force) and the other is very close to stripping (5-8 lb of torque on the bolt). If anyone has experience with this problem please provide some insight. I'm debating between helicoli it or cutting the tray and installing a new threaded insert.
