- Puerto Rico
Regards,
My SXR only start when I put the ground cable directly to the electrical box. I think is the stator. need heeeelp!!!!!...
I put the multimeter directly to the ground of the electrical box and it measures 11.7 VOLTAGE and when I push the start switch the multimeter measures 0.001 VOLTAGE.
(I can run the sxr with the ground directly to the electrical box?, If I do that the engine would not get damage or another electrical piece?)
