SX/SXi/SXi Pro Help with exhaust question? rubbing?
So i have a 2001 sxi pro, I put the coffman chamber pipe on it, it seems to be rubbing on the hull alittle bit? when the ski idles you can hear it tap off the hull wall...... any ideas? will it be fine? or do i need to put something inbetween the exhaust and wall?? move it?
Maybe try and turn it or rotate it. Little I'm not familiar with the pipe. Is it rubbing on the hull or a rib on the inside of the hull? Sometime b pipes will rub on the inside of engine bays depending on the set up. You can always push some hydro turf between the hull and pipe and just watch for when it rubs through the turf and replace, you could dent in the pipe a little on the area it's rubbing on or maybe your motor or something on the pipe is just not aligned properly making it rub...
