- Ontario Canada
I’ve got a 750 sxi, runs well and all but has wrecked 2 starters in 2 years. I finally looked at it and found the cover plate for the stator and flywheel is covered with brown dirt stuff, the flywheel is bumpy with what appears to be rust and the burnt starters also had this brown crust. A small amount of black oil was in the case as well. I’m guessing it’s a water problem. I’ve heard of blown crank seals allowing gas oil air mix into the case as well. I’m no pro, but I’m willing to work hard and I have a general knowledge of it, just requesting advice from a someone who actually knows their sh*t about skis. Also not sure if I should pull the engine to clean this mess.
