Please help with piston clearence! Motor New ADA racing cilindre, 8mm stroker with seadoo 90mm pistons. piston code 716M09000. There is no clearance on the box of piston Clear: 0.0000(0.000mm):thinking:
What brand of pistons? Wisecos? What kind of compression are you running? Dual or single cooling? What type of ignition? All these factors will determine what type of piston clearance you can use.
For your setup I'd run 0.0055" to 0.006" piston to cylinder wall clearance. If you were running Pro-X, I'd run 0.005" or so. Be sure to warm the engine up first to avoid a cold seizure.
