SX/SXi/SXi Pro help with porpusing
vitalikol
Jetski-Snowboard
Pennington,NJ
Jet Dynamics long one. But you can try more agressive intake grate or pump wedge, and try to position yourself more toward front . You may need shorter pole or shorter steering plate
JetPilot1970
Work at Sea-Doo Factory !
Quebec, Canada
What kind of ski you ride ?
I mean, the old 750 (1992 to 1996) does have a bump in the front hull... This bump pushes the waves and make the ski jump. Since the introduction of SxiPro in 1998, Kawasaki changed the front hull by shaving the bump.
Anyway I have a SxiPro myself and I performed this:
1) I extended the rear hull with hand made fiberglass extention 2inchs long.
2) I weld 2inchs extention on the stock ride plate.
3) I put 8 pounds of lead on each side of the gaz tank (Into the foam wich I've cut 2 insert.
I can tell you... This mods changed the ride in waves and on tight turn. My skis sits on rails now
If you need pictures, let me know.
gorilla
There's Always A Light At The End Of The Tunnel !!
Lost Wages NV
i have a 98 75osxi pro.
the stock sxr style ride plate was a hand full to try and control my boat with.
i put a worx long 306 ride plate, a wetwolf cone, and stock kawasaki pump wedge in-between the nozzle and pump on all at the same time.
what a nice handleing ski it now !!!
i can't even get it to fall over or shoot for the moon unless i'm in some serious chop !!!
and i'm 300 banana's heavy.
good luck
get wet
gorilla
