I have dual round bodied Mikuni carbs on a PJS dual manifold. I decided to junk the reserve/on/off tap as I also have a westcoast fuel pickup (both the main and the reserve are the same length). So I have two seperate direct feeds for each carb now.
My problem is that I have a fuel leak that is not only flooding my engine but also my hull. I think the base gasket on one of the carbs or a reed gasket is letting a slight leak into the hull but as for my engine!? Any ideas?
