Super Jet High speed screw seized - any tips?
nucleus_coolins
Does things to makes the do goods
High speed screw on my slave OEM 38 is seized.
Last night I soaked the screw area in wd40 and really tried to torque down on it, was only able to budge open maybe a 1/8th turn before the flathead on it got completely obliterated :(
Anyone have this issue before and was able to solve it?
Or am I at a loss and just need to buy another 38? :Flush:
I really wish they put T screws in for the high speeds and not just the lows...
Oh and its the coarse thread screw, pre 04 carb
nucleus_coolins
Thanks b.lee, yeah Im def going to try an e-z out. Probably as a last resort though, the screw metal seems pretty soft. But if it works it would totally be worth it if I dont have to buy another carb :)
Wondering if there are any other chemical solutions or something I could try before I go that route though.
nucleus_coolins
Wow, 60 bucks! I didnt know a set went for that cheap haha. Is there anything wrong with them or are they ready to bolt up? Shoot me a pic if you can and let your friend know Im interested.
Thanks Super_Slow_Jet!
Vumad
Super Hero, with a cape!
St. Pete, FL
WD40 works okay, penetrating oil works much better. PB blaster for example.
Propane torch kits cost about $10 at the hardware store, and replacement propane cost about $3
If the head is shot and you are calling the carb junk anyway...
Clean the head of the screw
fit some paper around the head of the screw to protect the carb
Fill the paper area with JB weld, make sure it only gets on the screw
Stick a screw driver, a dime, a piece of steel, something into the JB weld, let dry
Might work. If you are going to replace the carb anyway, it can't hurt.
nucleus_coolins
Wow never thought about using JB Weld to create a new head on the screw! Thats a great idea!!
Also, will try to find some PB blaster and get that screw turnin once again!!
Thanks Vumad :)
