Highroller stunt with 900 PV motor
Mich
Highroller Stunt hull in good condition with normal paint scratches, scoop grate, carbon ride plate, foot holds, dual scuppers, has an UMI aluminum pole with carbon pole pad, Wamiltons steering, finger throttle. 10mm Lamey PV motor 900cc, stock bore DASA cylinders, 49 Full Specs with Boysen intake, MSD total loss, Factory Pipe with flow valve, 148mm 14 vein Mag pump, Wamilton trim
$7500 Darrell 734 386 6657
Mich
Yes it is. Buy the parts and get the hull, pole steering for free as the drive train is worth the asking price. I am also considering transferring the parts into a flat water hull (carbon)
Mich
Yes the ski is still available. I was able to BF off a Boat wake (I am new to flat water skis) previous owner could flat water BF
Mich
It is sitting in my garage if you want to see it. I am available Monday if you want to see it. Give me a call or text at the number in the first post.
