Hitch cart
Vumad
Super Hero, with a cape!
St. Pete, FL
Just saw this ad on Facebook. Says 350 lb capacity.
Discuss.
HITCH IT, LOAD IT & ROLL!​
A CARGO CARRIER THAT ATTACHES & DE-ATTACHES FROM YOUR VEHICLE IN SECONDS - EVEN WHEN FULLY LOADED!​
HITCH-N-GO CART
MODEL HNGC-350
Patent # US 10,279,752 B2
The Hitch-N-Go Cart will make your life so much easier! No more making trip after trip, back and forth, toting your items. When you need an extra set of hands.....the HNGC-350 can be just that.
The Hitch-N-Go Cart conveniently fits through most doorways and the tight turning radius makes this cart invaluable when packing for trips. Just take the HNGC-350 to your items, load it's large, 48"w x 20"d x 11"h, cargo area and then transport everything in one trip to your vehicle. You don't even have to unload the cart! We have designed the HNGC-350 to install into the receiver hitch of your vehicle. And you can still access the tail gate or lift gate with no problem. You will need a 2" receiver hitch to attach the Hitch-N-Go Cart.
The HNGC-350 is so versatile that you can use it for many things. Whether it's vacation, moving things around your yard, picking up items from your favorite lawn and garden store or just anytime you need help getting a job done....Great Day's Hitch-N-Go Cart is designed to handle that need.
The HNGC-350 is constructed of powder coated welded aluminum that will not rust. It has 13" x 4" pneumatic tires and weighs 45 lbs. The cargo capacity on the HNGC-350 is 350 lbs.
  • Welded aluminum construction that will not rust
  • Durable powder coat finish
  • Vehicle receiver component doesn't have to be removed to access tailgate and/or lift gate
  • Coupling component can be easily stored in vehicle
  • Cart fits through most standard door openings
  • Tight turning radius for easy maneuverability
  • Large 48" x 20" x 11" cargo area (inside dimensions)
  • 350 lb. cargo capacity
  • 13" x 4" pneumatic tires (tire size/rim color may vary)
  • Complete unit weight only 62 lbs. wagon weighs 45 lbs.
  • Complete unit ships in one carton, 52" x 25" x 13"
DON'T WAIT ANY LONGER! CALL 866-649-1918 AND PURCHASE GREAT DAY'S HITCH-N-GO CART. $747.00
ASSEMBLY & USE INSTRUCTIONS
Vumad
St. Pete, FL
They have an option for just the lift assembly to use a different cart.
HNGC-350 LIFT ASSEMBLY​
If you already have a cart, but you want to be able to transport your cart easily by using your hitch receiver, then our Lift Assembly is the perfect solution. Will work on any brand cart that is up to 23" wide and uses a 2" receiver. Weight Capacity is 350 lbs.
CALL 866-649-1918 TO PURCHASE GREAT DAY'S LIFT ASSEMBLY. $317.00
And a beach tire kit for their cart.
HNGC-350 BEACH TIRE KIT​
HNGC-350 BTK
Great Day’s Beach Tire Kit comes with everything needed to turn the popular Hitch-N-Go Utility Cart into the best beach cart on the market. The 12 x 7 balloon tires allow the cart to roll across soft sand like a breeze.
No tools are needed to make the conversion, just a few minutes of your time. The balloon tires also allow the Hitch-N-Go Cart to maintain it’s 350 lb weight rating.
NOTE: DO NOT over inflate the tires. Maximum inflation pressure is 3 psi.
CALL 866-649-1918 TO PURCHASE GREAT DAY'S BEACH TIRE KIT. $377.00
Vumad
St. Pete, FL
I had once looked into this but stopped because harbor fright discontinued them. Would have just made a bed load easier because I don't think it was deigned to have the weight during transport, only supported while loading. Not having to take bed space with the cart is appealing. The preceding posts look interesting.
Vumad
St. Pete, FL
They already have a beach option! 900$
Yeah, seems like the frame might now work great with a SJ or B1. I didn't see those accessories listed on that page but that cart is displayed with rod holders and tackle station, or something like that they called it.
Maybe just the life mechanism with the harbor freight cart with bunks on it could work.
