Cannibal
Tasty Human
- Summit Lake, WA
First off, this idea would be implemented on an SXR, and I don't believe any of the production adjustable foothold systems out there will work on the SXR because of the curved back end and they utilize an outer bracket that sits flush against the hull, plus I'm a cheap a$$.
Secondly, I'm not trying to copy anyone either.
My SXR is cut to pieces, so I really have a blank canvas to do what I want. What I picture is a system that is contained inside the ski, no outer brackets of any kind. The best idea is already taken, but would be A LOT of work, and that would be to implement a bolt down tray like a Lightweight and have the adjustable footholds attached to that. I am not going flat deck, so the footholds can't bolt to the underside of the bond rails or have any bolts from the outside to access.
What I'm thinking is this: Either glass in a 1/4" piece of aluminum (maybe some thin stainless with nuts welded to it) into a recessed gunwale or glass inserts in certain locations. The part that sticks out (the hold) could be more 1/4" aluminum with some larger threaded "bosses" welded to the top and bottom (maybe some thick glass with coupling nuts?). This piece would bolt to another piece of aluminum with different holes in it for height and attitude adjustment. That plate would then bolt to the plate that is glassed into the gunwale and be adjustable front to rear.
To adjust the foothold height, you'd need to remove the plate the hold is bolted to and access the bolts. To adjust them front to rear, you'd just unbolt that plate and move it fore/aft to another tapped hole in the glassed plate.
Anyone have any input? Better ideas? Criticism? Etc?
