Super Jet Hood adjustable?
I’ve got a Wamilton hood and just did watcon seal. The hood sits pretty far back and is moving the seal out of the way. I’ve got cold fusion attachments on the hood but the stock hooks on the hull.
The stock hooks didn’t seem adjustable. Are there aftermarket hooks that are adjustable? Or what’s the best option?
john zigler
Vendor Account
wisconsin
We have done a few Wamilton's hoods, and I have had to slot the hook holes, and if I remember correct even ran one set upside down to get it to sit correctly.
wydopen
onthepipe
I have some ada hull side hooks also...sometimes you have to do some grinding/shimming to get them to fit right...usually wamiltons hoods fit perfect though..the waterlogged krustoms hood Im using now didnt fit at all...had to slot bolt holes for hood side hooks and shim the hull side ones allot...there was a bulge where one of the hooks mounts and even with all the shimming/grinding it still doesnt go in and out of hooks easy..
Thanks I got 'hooked' up and waiting for ADA hooks to arrive.
I don't think it's a shimming issue because shims would just push it in the wrong direction anyways. The hood is probably sliding aft a bit and the hooks should help. If not, I'll probably fill in the holes for the hook screws in the hull and relocate slightly towards the bow.
