Surfriding Hood repair ideas
ThatGuy
NJ
I have a blowsion JK freeride hood and it is starting to seperate. Anybody have this problem and or know a way to fix?
Should I sand it and put some resin on it and clamp it. Then hope it works or is there a stronger way to fix?
2010brandingo
TEACH ME HOW TO DOUGIE!
ATL
scuff it as good as you can, put some J-B Weld on it and clamp it, should hold fine. Just don't use the quick-set type... not as strong.
I'd use a product more appropriate for fiberglass, like thickened epoxy resin. But I will admit I've never JB Weld on glass.
ThatGuy
NJ
englewood nj yea i can't stop reading the posts i have a feeling that my skis are going to get sicker but my wallet is going to get thinner. But i am fine with that.
ThatGuy
NJ
so try J-B Weld first and if i crack it open again go with the resin? All in favor of this plan say I.
I'd just do it right the first time and save myself extra work and aggravation.
Jmho
ThatGuy
NJ
and right is resin correct? a little worried about it because there is not a lot of surface area for the bond
2010brandingo
ATL
come on people... epoxy resin alone has no strength. if using it with glass or carbon of some sort then yes. J-B weld is an epoxy-based "panel bond". and to help prove its tha shiz.... cracked the engine block in my jeep about 20 inches long 3 years ago. cleaned it, scuffed it, J-B welded it.... still good to this day. try that with some resin.
i know it may sound a little off the wall, but i've been doing custom paint/body work for over 20 years and you will be suprised at what you can do with this stuff. and yes, there are other "panel-bond" adhesives that i would also suggest but at @ $40-50 a tube and the price of the "special gun" it takes to use it this is a great/cheap alt. IT WILL WORK!!!
