Hood seal replacement
Going to replace my hood seal but wanted to get an opinion of what product should i use to attach the new seal to my hood. Any other info/tricks regarding hood seals\ keeping water out is appreciated for future knowledge of myself and others. Thanks guys
Sanoman
AbouttoKrash
NE Tenn
l like using 3M black weatherstrip adhesive.lts a little stringy,but l haven't had any issues with it.You apply a thin coat to both surfaces,doing a foot or so at a time.lf it does come loose late on,you can just apply a little more to the area and still holds.Used several other glues in the past with varied results.Some guys swear by super glue,but it's a little tricky to work with.Not my favorite
Thanks guy, i assumed super glue but, i also wondered how hard it would be next time it needed replacement. Ill check out the weathersrip adhesive
