Anyone have ideas why my ski would be running scalding hot? I've got a single cooling line coming from pump that splits to a T for the mani then out of one side of cylinder head to bottom of head pipe then out of b-pipe to a T for FCV and other side to pisser. The other side of head goes directly out to pisser. NO RESTRICTORS ARE IN LINE. Both pissers are flowing freely. The water coming out of the pissers is hot!! I didn't check the temp of it, but when it hits my legs it scalds them. I'm gonna run a second cooling line off my pump to the manifold and see if dual input helps cool it down some.
In addition to that the engine side of the coupler is hot as hell too. I don't know if that's transferred heat from the cases or what. I just had CP Watercraft do a engine build for me (true& weld, bore, port, epoxy) and it starts and runs fine. Does a built up engine run any hotter than stock?
