- Anaheim
I have a 750 sx and it has an aftermarket ride plate and intake grate but it still seems to bounce a lot at high speeds. How should i fix this?
dont d-cut your plate to get the nose down, that will make it worse. Also tubbies are a great addition to your ski but will not add any nose pressure, you actually loose a little. Tray time is key to getting the nose to stay down, also they make hull extensions that will really keep the nose down. They are great for racers since they make it turn on a dime and keep the nose planted. I have a used set if you want them.
