- new port richey,fl
I have an 04 superjet and I wanna turf the side rails. How much turf do I order or is there a kit for it already? And what glue should I use?
Sand both surfaces...... apply 2 coats to the turf. one to the hull........ Let dry, proceed to adhere, but first, set it back down and go drink another beer....... Install turf. Use a rubber mallet and beat theout of it. This helps to fuse the turf to the hull.... Gives new meaning to "Contact"......... Trim the edge of the turf with a razer blade at a 45 degree angle.(This way water spray does not it the turf and try and pull it loose) You can use a sanding block to smooth up........ Where the turf meets the side of the hull, you can caulk this with Black RTV silicone. This will help to keep water from getting under the turf and causing it to turn loose. where you shaved/sanded, you can run a small bead of superglue to help bond/seal the underside. Also superglue any seams together if you do not have a full run of turf from front to back.
You dont keep a ski long enough to find out!!!!!!!!!!!!!!!!!!!!!!!! Did I just say that??????????
