Your favorite number, I presume?
More partial to 13, but i dont think you can fit that many in thereYour favorite number, I presume?
The fact that guys will spend 20+k on a freestyle ski then talk about pool noodle tech is hilarious
My normal ride spot is about 10' from shore in 6' of waterYou can't expect to take a hull designed for competition in to the wild for fun without properly foaming it. The point of it is to make the jetski go upside down as close to spectators as possible
I think one noodle will float something like 5-8lbs.
Also they will eventually hold onto water if submerged long enough.
Doesn’t sound like pool noodles could even work to make 250# buoyant
Weird, If that is the case I need 36 Noodles for when I go to our neighborhood pool!!!!!!!!!!! lolI think one noodle will float something like 5-8lbs.
Biggest thing that will keep your ski afloat is making sure the exhaust doesnt come apart from the coupler or hose coming loose that let's water into the engine compartment quickly. The tigercraft that's at the bottom of the lake is a friend of mine and I was there the day it happened. Underrotated barrel roll is all it took. He has a bpipe and we're pretty sure the headpipe coupler came off or an exhaust hose came off. The ski was gone in less than 2 minutes.
