How much does the SXR 800 engine weigh?
Lammy
winter sucks
St. Louis
Just as the title says. I searched as much as I could but I couldn't find it. Need to find out if it would be good on a hovercraft... :biggrin:
Waternut
Customizing addict
Macon, GA
Well it's not exactly 800 but close... My 750 weighs roughly 90 lbs with bed plate but without the pipe and carb... Factory Pipe and carb are roughly another 20 lbs.
add water pump and radiator to that plus coolant. You'd have to go to some sort of dry exhaust system too. It might work. Probably worth a shot I guess.....
