Other How much psi do you think is in the cooling lines
How much psi do you think is in the cooling lines?
I'm looking at using a lighter more flexible type of pvc hose for my cooling lines and want to make sure that they can handle it without bursting
sjetrider
when testing the flow control valves with popoff gauge i never saw over 18psi. This can obviously vary greatly depending on how your lines are run to the pump and where you have them entering from and going out, how many splits and do you restrict to your stinger. I would count on 30 psi and hope you never get a sea shell stuck in an outbound side as I have done. Thet will increase the preasure in other areas as well.
