Super Jet how much turf do i need??? help!! i need to order asap
i have a sn that has footholds im about to turf. i am buying sheets of turf 40" by 62". i want to turf the rails and the nose i also want to turf the front of the tray and a square piece of turf on the hood to support the pole.
can i do all that with the one sheet of turf or do i need two?
i need to know asap so i can get this project done!!
many thanks!!
Texan33
Yacht Wakes Hunter
Texas
Just the front of the tray as in the front wall? It's possible to do all of that with one sheet but you can get two just in case. You can never go wrong with an extra sheet for later.
I went with 3 sheets. i have some leftover but if you screw up you'll be pissed! I did my tray with footholds, pancake pete, chin pad, nose and rails.
yeah 2 sheets.
Check out the "b-stock" too, it's less expensive if they have the kind your looking for. Hard the tell the difference.
