How to install baffle to hood?
Just picked up an aftermarket hood superjet hood. The hood is in two sections, baffle and hood. What is the best way to install it. Is it just bolted at the front and rear? Or is it epoxied or glued together? 3m 5200. The top of the baffle doesn’t fit exactly flat due to the bump out for the pipe so it doesn’t seem there a a lot of contact for epoxy to sit. Also what hood is this, looks to be a 24/7 or Bun hood.
The hood liner would normally be glued in. Usually with thickened epoxy resin, or maybe even g-flex. 5200 might work, but I think it is too flexible.
