surferdude345
X-H
- Blacksburg for school
So i was inspired by WDKfan's build up and how he made a fuel filler, i took some of his ideas and i think improved on them.
What you need:
Stock Fuel cap/threaded thing
Some fuel line
From auto store:
Flared brake line - each piece about 16" Preflared is easier and cheap
2 90 degree - thread to flare fitting
From lowes
A-197 Hose barb adapter 2 needed
A-738 pipe hex bushing 2 needed
By the pvc - 2 Inch to 1.5 inch reduction rubber coupler
2" or 1.5" Rubber cap- 2 is a little to big 1.5 is real tight ur choice
the major difference from what i used to wdkfan's was i used brake line and flare fittings because the compression fittings look like they would restrict fuel
flow. Also the Rubber coupler.
Basically when you get the parts its pretty easy to see how they go together.
I drilled out the stock filler with 2 holes for the brass fittings then sealed the fittings in with 5200. I Cut the reduction coupler about a half inch on either side so it would clear the hood. then sized the brake line- i cut it about 2 inches off the bottom and put fuel line over the brake line to the bottom of the tank.
This less then 30 bucks to build and it comes pretty nice
What you need:
Some fuel line
From auto store:
From lowes
