Super Jet How to remove sticker residu ?
Quebec
So I just purchase a Superjet that had flame on it. So obviously, I removed them !
Now, I have to remove all the sticky residue from the decal.
I tried Goo Gone which didn't work at all !
I tried lighter fluid which didn't work!
I tried brake cleaner which work ok with a paint scraper but It scratches all my paint and there is still residue left
I tried a pretty aggressive product that remove everything including the glossy of my paint :mad:
It took me 1 hour to do only the hood.
Thanks for your help
MikeyB
H2O-Addict®
Michigan
3M General Adhesive Cleaner and if that doesn't work I use one of these
BruceSki
Formerly Motoman25
Long Island
I use a rubber eraser wheel and a little acetone on a rag to get that stuff off. Its easier to use the wheel while the sticker is still on though.
make sure to clean and wax after getting acetone on the paint.
EDIT: The wheel is like that^^^^^^
Quebec
the eraser wheels are great for the decals, but goof off or acetone works real good to remove the residue
Yeap, I'll need to use acetone to remove everything. It leaves a matte paint finsh but I'm going to wrap the hole superjet ... anyway it's a pain in the as* lol
JT_Freeride
John Tetenes @Jtetenes
Long Island
I used Mek on a rag with one of those plastic drawer dividers that are in tackle boxes to scrap it off. It works really well and doesn't scratch cause its in the rag.
Ak
Napa paint center sells eraser wheel kit including air tool for about $40. Best $ I've spent in a while. I stripped an entire 94' 550 of decals in 45 minutes. Took 2 wheels to do it but they were like petrified stickers. Go get one!
Meguiers cleaner wax
Edit if you care about the paint..
Man you should have put the heat to that as soon as it started coming off like that..
canada
We use gas on a clean rag to get that off. The turf came off the rails of our sxr and the glue was still on there and the gas even took that off, we just had to scrub really hard. cant even tell anything was there now
