- United States
how do you test to see if your CDI is working?
If the LR module is bad it will not send power to CDI and it will not spark. Hooking red/purple wire directly to power by-passes this problem for testing purposes.
Hooking the red/purple wire from the cdi to another red/purple wire stops the LR module from effecting the ignition system. As it is wire from the factory power to the cdi is controled by the LR module, which will only send power to it when it senses engine rpm.
Just hook the red/purple from the cdi to another wire of the same color (which should be hot at all times).
