- Tualatin, OR
Anyone know how to test carb spring weight? I don't think color is as reliable as it once was. IE a 95 gram spring. Is that the weight of the spring or the spring force at a set compressed length? Thanks.
3-4Lbs ?!? I don't think they vary that much.last 2 years the 95 gr springs from mikuni are 3-4 lbs less than they used to be
mukini springs are all over the place it seem anymore
I think he meant 3-4psi3-4Lbs ?!? I don't think they vary that much.
yesI think he meant 3-4psi
Apsolutely, it's takes several springs to find a mate if running dual carbs. I've never gone by the specification found in the book.last 2 years the 95 gr springs from mikuni are 3-4 lbs less than they used to be
How many of you bend the needle arm to tweak pop off pressure?
