Hull repair - sugestions
So if you have tiny gash and nicks on the bottom of the hull how would you repair them. I know people say leave them untill you see light but I like to safe. So what did any of you do to fix them?
SJBrit
Extraordinary Alien
Bradenton, FL
If they're not deep then go grab some Bondo and some appliance enamel. I really don't put much effort into keeping the bottom of my ski pristine - it's very hard to keep it that way.
WaveDemon
Not Dead - Notable Member
Hell, Florida
I don't think the bottom of an smc hull is the best place for bondo. It might work but it will be a mechanical bond only because it's polyester based and bondo loves to absorb water when it's exposed.
SJBrit
Extraordinary Alien
Bradenton, FL
Indeed, but any filler is a mechanical bond on the bottom of the ski. The only way to get a chemical bond is monolithic curing, and that SMC hull has long since cured. Epoxy with a faring filler will also get rubbed about pretty quickly once the paint wears of - so the only permanent fix is epoxy + cabosil which is a pain to finish.
So, my vote is do it cheap, paint it with a hard paint, and then do it again when it wears off. Or maybe you learn your lesson the second time around and just leave it :sneaky:
wa
fibertech is the best stuff on earth. get from any autobody store. the stuff works wonders on anything and wont crack.
