hydro turf?
Gmoney1968
Gmoney
orlando,fl
new to the site love this place anyway i know this is kinda broad ? but whats the best way to strip of the old mat ant put on this new hydro turf i gots ? thanx G
Shonuff
I've got the glow
Memphis
Do a search for "remove hydroturf" and put your reading glasses on.
Tons of tricks and tips.
Good luck - go buy a heat gun.
Get off what you can by simply pulling a little up at a corner, slicing the underside with a blade, the pulling more up. Then use a 5" sanding pad on the end of a drill. You can prep the tray for turf in an hour. Don't do what most people do and try to get it looking perfect. You should scuff everything before you lay the new turf anyway so why worry about it looking pretty?
Use the heat gun when you put the new stuff on
SJBrit
Extraordinary Alien
Bradenton, FL
I used a wire wheel. In any case, you are correct: hack at it with power tools and the uglier it looks the better the glue will adhere.
