I don't think the search button is working...
WaveDemon
Not Dead - Notable Member
Hell, Florida
I'm trying to find the old tnt thread where we talked about cutting up a blaster mod.
the search results are all messed up. is it me or is there a problem?
SuperJETT
none
The search index doesn't do 3 letter words I think. I can change it, it's just a performance hit because of the massive amount of 3 letter words.
SuperJETT
none
That's what I'm doing actually. I didn't think of CDI, any others that people can think of?
SuperJETT
none
If we can get a list of 3-letter words that need to be included, I'll add those and rebuild the search index.
tap
bit
nut
gas
ODI
UMI
XFT
wow, if you consider company names, you may wanna make it so it wont search for 2 letter words.
how does it affect performance? if someone doesnt search for words like "the" and "and", it shouldnt cause a performance loss. right?
SuperJETT
none
sflsurfrider said:
tap
bit
nut
gas
ODI
UMI
XFT
The index of words gets quite a bit larger when you add in the 3 letter words. Stuff like hat/hot/hit/hut pat/pet/pit/pot/put add up quickly.
And yes sfl needs to be in there...:cheer:
SuperJETT
none
Alright, I rebuilt the search indexes with these extras so it should be better now. Let me know if you want more words added.
how about:
jet
ski :banghead:
here are some more....
cap
bow
eye
red (pipe)
pop
off
psi
mil
5mm
6mm
7mm
8mm
9mm
lip
big
pin
bog
sbn
air
pre
mix
(flat) top
ecm
npt
low (high)
res
rpm
per
gas
oil
wcf
can
(woodruff) key
mag
pto
mid
(drill) bit
hot
pro
tec
tap
die
ass
Y
yamaslut
Guest
Rickster said:
Darin already said that SFL would be part of the group.:biggrin:
:joke:
OMG!!!!!!!!!!!! that was funny
