finished installing a hooker 9/15 and I cant get the impeller tool off after torqueing it down... was using a crecent wrench to tighten it and it kept slipping
That is real easy! look at the tool, you'll notice it has become oval shaped from the wrench compression. take visegrips and squeeze it round again and it will slip right off, duh!
yah I ended up pulling the impeller back off removing the tool and using and older one that is less oblong, but thatnks for the hlelp I'll keep that in mind for the impeller I'm changing sunday
I went to harbor freight and got some large box end wrenches. Cut off the crowsfoot end. Use on impeller wrench, slip a length of galv. Pipe from home depot electrical. Makes it easier to remove tough ones without killing the tool. Solas impellers are the worst for killing the tool while removing.
