I keep breaking my b-pipe bracket....suggestions?
So, after the stock FPP bracket that attaches to the side of the gas tank broke, I made one out of all thread and a rubber dampener. Then the tab that is welded to the side of pipe broke clear off at the weld.
Anyone have any innovative ways to keep these things in tact? I do alot of jumping, so I know this puts alot of stress on the pipe, I just don't know what else to try. By the way, this is a limited chamber.
Dustin Mustangs
uʍop ǝpıs dn
Holland, MI
Some of the limited chambers (I assume the newer ones) mount to the tank and the cylinder. The mounting on the cylinder is identical to the way the mod chamber mounts to it. If you search, you can find pics showing both styles, tracings of the brackets needed and info on where to get the lord mount.
